Oliver Valve Spring Upgrade?
JDH
12-26-2006 16:18:43
What valves can I use that have a stronger strength than the 50# of the stock? The 195 valves are larger diameter and don't look like they will work without machining the head. Is there a spring with more strength than stock and will work with the stock keepers,locks, valves? Thanks
88Power
12-26-2006 19:45:50
 Re: Oliver Valve Spring Upgrade? in reply to JDH, 12-26-2006 16:18:43
Need more info: what cylinder head do you have, what valves are in it (I'm assuming stock), and what is max RPM you want to run?
JDH
12-27-2006 04:59:56
 Re: Oliver Valve Spring Upgrade? in reply to 88Power, 12-26-2006 19:45:50
It's a 880 (3-7/8) motor and head (stock valves)with 1650 manifolds. The head and manifolds have been lightly ported. Bullet cam with little duration, so they need to close fairly quick. I run 3000 max rpm. Mostly around 2500. Any ideas on off the shelf springs that would be close? I am trying to get ready for Florida in Jan. Thanks,
88Power
12-29-2006 18:48:08
 Re: Oliver Valve Spring Upgrade? in reply to JDH, 12-27-2006 04:59:56
For 2500RPM, you don't need much, but you'll need more than 50lbs seat force. You can do one of two things:
Easy and cheapest: shim up your current springs to the point of .060" clearance to coil bind at max lift.
Or: get new springs and retainers to get you to 90lbs. seat force and no more than 250lbs at max lift.
