US G ROD LENGTH AND PISTON LENGTH.
Miller49G
12-25-2006 15:31:46
I need to know what the length of a US G rod is center to center. A Styled G is 13� center to center. Also would like to know the length of an US G cast-iron piston end to end. A Styled G cast-iron piston is 8 �� end to end. And were the US G connecting rod pin is centered on the cast-iron piston. The Styled G rod pin is centered 5 �� down from the top of the cast-iron piston. Any help would be help full.
skip 33652
12-25-2006 17:26:47
 Re: US G ROD LENGTH AND PISTON LENGTH. in reply to Miller49G, 12-25-2006 15:31:46
the rods and pistons are the same length the rods I think are the same #'s. the pistons are not quite identical but close enough the blocks however differ in length by 1" Paul
