JD B rods
MN JD
12-24-2006 20:44:33
Working on a 38 B and just wondering what rods are being used with a 7.5 inch stroke. Have a set of 4.75 inch pistons and wondering if the stock rods will work with the short piston I have or need to build ones.
jd b puller
12-25-2006 10:53:29
 Re: JD B rods in reply to MN JD, 12-24-2006 20:44:33
I like the Waukesha 310 rods. They have a bigger journal than the Farmall Rods and are a lot beefier. And seem to clearance as good or better. Journal size is 2.4375 vs. 2.25 (H) or 2.3 (300).
MN JD
12-26-2006 19:39:46
 Re: JD B rods in reply to jd b puller, 12-25-2006 10:53:29
Where can you find those rods? Will some of the machine shops have them on hand? Thanks MN JD
es
12-25-2006 07:33:52
I might be wrong but i think there welding farmall H bottoms to B tops or have custom one made
