Electric Fan Pusher or Puller ??
Hank L
12-23-2006 22:36:19
I want to put a electric fan on our 88 Oliver.The fan I have would be a lot less work to put on if I installed it in front of the rad(pusher).Does it make any difference as far as cooling if the fan is in front of the rad or behind it?
88Power
12-25-2006 11:00:17
 Re: Electric Fan Pusher or Puller ?? in reply to Hank L, 12-23-2006 22:36:19
Location of the fan won't make a big difference, but direction of airflow will. You want to set up the fan to blow air from the front of the tractor, through the rad, into the engine compartment, and out the side curtains. This gives the largest temp drop across the rad. If it flows the other way, the air temp in the engine compartment will greatly reduce the effectiveness of the rad.
johndear
12-24-2006 07:53:21
I have a puller on the front of my Farmall M. Since I rarely drive it 40 MPH down the highway I seldon have a problem with the air being drawn towards the front of the tractor instead of towards the engine. No reason you can't run a puller on the front. Suction fans almost always cool better than pusher fans.
Jim Johnson
12-24-2006 07:49:17
You might not have room but on my W-9 it's got one front and back.
AC Boy
12-25-2006 15:25:01
 Re: Electric Fan Pusher or Puller ?? in reply to Jim Johnson, 12-24-2006 07:49:17
Jim the pig Johnson!!!!
Mike Aylward
12-24-2006 07:08:56
Hank, for the most part it won't make a lot of difference but it can make some in the amount of airflow. I have a fan mounted in front of the radiator on mine but it was because of room considerations that I did it. On many fans the blades are cupped and while they will still move air going in one direction they won't move quite as much air as they would if they turned in the direction favoring the cup of the blade. Hope this helps. Mike
dogleg
12-24-2006 03:28:48
No it shouldn't.
