JD B axles
MN JD
12-20-2006 19:08:58
Will axles out of a newer B fit in a unstyled B? Wondering if changing the axle bearings and axles from newer one would fit. Or, how hard is it to find a set of hubs for pressed steel wheels for an unstyled B?
keddano
12-20-2006 21:08:35
 Re: JD B axles in reply to MN JD, 12-20-2006 19:08:58
The 12 spine on outer axles will fit in the 10 spine outer axles. The unstyled hub are out there...How big of check do you have? Get a newer set and put weld-ons on.
