Farmall SM oversized pistons
jhb
12-20-2006 10:18:10
What pistons, I think 4 1/4 inch diameter, will work in sleeveless SM Farmall block with SM rods?
Does anyone have any knowledge to help me achieve my goal? I realize I may have to make the wrist pin bushings for the rods and probably M rods may work better to get a little offset on the wrist pin. I have done this before on a Farmall H.
SUPER MTA PULLER
12-20-2006 11:09:06
 Re: Farmall SM oversized pistons in reply to jhb, 12-20-2006 10:18:10
M and W made a bolt in 4.250 also sleeves which require block boring.Good luck finding a set .I ts been about 4 years maybe 5 since ive heard of a few stragglers having a set.Power seal in Des Miones went out of business about then.They were the last known supplier.IF you want to stroke it then U MM 420 or 4026 lp John Deere Chevy truck 427 just depends on pin height.Typo above should be4020 jd lp.For around 550 bucks you can have a custom set made.
