So how close are the new tractor coming along
kansas puller
12-18-2006 11:16:08
So how are the new tractor building coming with everyone, I have mine almost finished , I have changed classes i have built a modified tractor this winter to pull with the kansas truck pullers ,and have a g on the back burnner for next year, well got to go merry christmas
mark
tired deere
12-21-2006 18:46:35
 New 460 ih tractor in KY? in reply to kansas puller, 12-18-2006 11:16:08
apparently there is a new 460 farmall in KY for 07. Pulloff.com post says its an all alum. tractor built by binderlite... anyone have any info? who did the engine? what class?
Dairy Farmer
12-20-2006 18:27:29
 Re: So how close are the new tractor coming along in reply to kansas puller, 12-18-2006 11:16:08
I been workin on a JD 4440 open station. Installin a new turbo to try to get over 225 HP outta the 'ol girl. Not stock engine butstill needs a clutch and some paint, tires and other parts and she'll be all ready to beat them binders ;)Just my 2 cents DF
Mopower
12-20-2006 03:24:54
As usual, I've been working on everything else but what I should. Selling off MM parts and extra tractors.
mike's600
12-19-2006 18:30:00
mark ,how about those Mh brakes.I got the wheels off(heavy)getting ready to add the roll bar. The frame rails are just a little tight to get the stock brakes installed. I should have everything worked out soon. mike
TOOTHLESS FAT CHICK
12-19-2006 09:48:34
HI KANSAS! ARE YOU TAKIN ME WITH YOU AGAIN THIS YEAR?
GO AWAY
12-19-2006 17:37:12
 Re: So how close are the new tractor coming along in reply to TOOTHLESS FAT CHICK, 12-19-2006 09:48:34
Here go's Mark talking to himself again.
Mark, you do not need this site to talk to yourself
Adam Brock
12-18-2006 17:10:17
Ive got a Farmall 504 that Ive bolted 460 frame rails to and am building a Farmall 606 with a C221. Its gonna be pretty light I think I can pull 4500 - 6500.
Ken B
12-18-2006 15:05:46
Waiting on parts hope to perk up the boys H I was told it was shipped Mon I meant this Mon. Ken B
Kevin Tarbox
12-18-2006 14:52:40
Rebuilding my JD 60 Named Southern Thunder. Stock stroke, nothing speacial, estimated to be around 75hp. Running 7500 8500 and 9500 in antique stock classes.
rx7
12-19-2006 20:26:31
 Re: So how close are the new tractor coming along in reply to Kevin Tarbox, 12-18-2006 14:52:40
may i ask how you think your gonna have 75hp outta stock stroke???or is that one of them "outta the air numbers?"??
Kevin
12-21-2006 09:13:21
 Re: So how close are the new tractor coming along in reply to rx7, 12-19-2006 20:26:31
Id like to know how you think it is imposible. Ive seen one built identicle to how i am building mine and it was right at 75hp, stock stroke. The set up is using a powerblock if that answers anything for you.
Drew
12-21-2006 11:20:53
 Re: So how close are the new tractor coming along in reply to Kevin, 12-21-2006 09:13:21
75 hp at 540PTO, or pulled down? It may show 75hp pulled way down, but when you correct that number for the lower RPM then its not 75hp.
Even if its a power block cut out and sleeved big, I still think you're dreamin'.
Jak
12-18-2006 14:47:14
Not a new tractor to me but the paint will be.I forgot how much time is involved with block sanding and preparation.The sheet metal looked very good till the old paint got stripped and there are little peck dents all over.Them old Ollies have lots of sheetmetal too.
JDH
12-18-2006 13:39:50
Still waiting on parts and machine work. Hopefully back together before the new year. For some reason there are lots of other tractor engines in the machine shop slowing down my progress! Ha Ha
ChadS
12-18-2006 14:10:56
 Re: So how close are the new tractor coming along in reply to JDH, 12-18-2006 13:39:50
Im not working on a new one,,, Im resurrecting one. 1940 Farmall H modified. I keep selling the blocks Ive built to replace the one I need, but this one aint for sale this time! Well on its way this time around. Hope you fellas have not forgotten the saga of Something Wilder. If so, a reminder is coming. HAHAHA! Oh yeah! its baaack!! ChadS
