Chad S H Pistons
Dave S.
12-17-2006 12:18:09
What is the best brand of high compression, over size bore piston and sleeve set to get the most HP out of a 45 H?
77
12-17-2006 21:08:18
 Re: Chad S H Pistons in reply to Dave S., 12-17-2006 12:18:09
What about 3and5/8 in the block no sleeve.Any piston that you like.
ChadS
12-17-2006 12:35:00
The best is the 350 firecraters, but, you have to bore the block to get the sleeves to fit,,, 3-7/16 overbore is all thats available for drop in kits, but,, there is a kit outhere that uses the same piston domes that the new 450 piston kits. They have a double hump dome that is taller and better than most of the half moon shaped traditional style domes. The 450 pistons are made by confortmatic, red power pistons may be the same too. Only other option would be to run no sleeves, and a set from a 300 C-169 which is 3-9/16 bore,, if those are available still, they have a few different domes shapes,, including firecraters. Id have to double check the H block bore with no sleeves to see if they will drop in,,, but Im thinking that they might. Some were 3.5 with no sleeves,, some were 3-9/16,,, Now if they are 3.5,, look at Super H pistons,,,, Chad
MJF
12-19-2006 19:49:16
 Hey Chad whats these confortmatic pistons in reply to ChadS, 12-17-2006 12:35:00
Hey Chad I've never heard of those confortmatic pistons. Is there a website or something I'd like to see them
ChadS
12-20-2006 10:00:39
 Re: Hey Chad whats these confortmatic pistons in reply to MJF, 12-19-2006 19:49:16
They are whats typically sold in new aftermarket kits, red power is the same design too. You will see them alot more common in the SM-450 kits,,, but have seen em made for the H's too. Chad
another H guy
12-17-2006 14:28:47
 Re: Chad S H Pistons in reply to ChadS, 12-17-2006 12:35:00
What style pistons for the 350 do you sell Chad and what do they usually run price wise.
