JD A reduction gear change?
jdjack
12-16-2006 16:21:21
I have a 44 JD A and want to install the later model reduction gears (single stick tranmission).
I know that i need the reduction gear and the belt pulley gear. Can the belt pulley gear be pressed on my belt pulley, or do i need to swap complete pulley? Then will i need the clutch fork from the single stick? Am i missing anything else?
Thanks for help.
Rusty Junk TX
12-17-2006 04:06:06
 Re: JD A reduction gear change? in reply to jdjack, 12-16-2006 16:21:21
Swap the complete pulley. Use your existing fork unless the parts tractor has a better one. Sounds like you are on the right track.
Marcus
