ChadS
12-18-2006 14:50:33
Re: ARP Farmall M Head Studs in reply to mperfection, 12-18-2006 14:32:31
Id be more afraid of a big stroker comming apart. If you have had this thing all apart, and all the bolts been retorqued, I would not worry too much. But if it hasnt,,, Id go back when you have time, and pull the flywheel and clutch apart, clean em up, make sure its straight, put in higher grade bolts for the pressure plate, and make sure the flywheel bolts are tightened to specs, and old tractor that has been running for a while,,, lets say 25 years of hard work since its last rebuild, Id be leary,,,, they will come apart,, eventually,, so,, Check the input shaft bolts on the tranny,,,, replace them if needed, or just for kicks,,, thats where it usually starts to break,,, run new oil and the thickest your weather will allow you to have in the rear end. Do you have any kind of wastegate on the turbo?? are you operating it by hand or??? Yeah, 15psi for a while should be ok,,, just get to know it better,,,, listen to it, dont get stupid,,, A rednecks famous last words are,,, "Hey ya all!!! Watch this!!!" K??? My email address is [email protected] Lets see what you got! ChadS
