Farmall M governor wieghts
jhb
12-14-2006 16:45:15
Does anyone know what the governor weights are supposed to weigh on a Farmall M, SM, 400 or 450? Also how much should one grind off them to lighten them for standard rpm pulling? Any help/information on this topic will be greatly appreciated. Thanks in advance.
ChadS
12-15-2006 07:55:49
 Re: Farmall M governor wieghts in reply to jhb, 12-14-2006 16:45:15
You can take about 1/2 of that weight off there by using a belt sander. Its a big enough change to not need to go beyond that point. Yeah, you can go too far,,, but its only downsize is that it may surge at idle with no load,,, find a digital scale and weigh them, keep them within a few grams of each other so it dont get out of balance. Chad
