BIG CARB
Curious
12-13-2006 23:52:27
What kind of carb are most of the big M Farmall's running? thankyou
Real Puller
12-15-2006 06:06:39
 Re: BIG CARB in reply to Curious, 12-13-2006 23:52:27
The secret to making a M carb work, is to open up the venturi. What good will a bigger inlet help if it still goes thru a small venturi? The big motors run a venturi that is 1 1/4" to 1 1/2" ID.
More air, more fuel, more power. If you want your M to run good at 700 rpm, use a stock venturi. If you have a big motor and want big power at the higher rpm's, it take a big carb to feed it.
A real what???
12-15-2006 08:11:29
 Re: BIG CARB in reply to Real Puller, 12-15-2006 06:06:39
Figured that out all by yourself did ya?
Mopower
12-14-2006 03:17:49
Farmall M's used only a Farmall carb to work with their governor. An M carb pretty much has to be used but many are enlarged internally. I do not know the specifics, but Gary Baker builds some fine large M carburetors from stock.
Curious
12-14-2006 07:50:51
 Re: BIG CARB in reply to Mopower, 12-14-2006 03:17:49
Is Gary starting with the M carb on the stuff he runs?
thankyou
Mopower
12-14-2006 08:33:38
 Re: BIG CARB in reply to Curious, 12-14-2006 07:50:51
I believe so unless there is a big difference or advantage in using a 450 carb. Best to ask him. I've seen them make a noticeable difference in a couple machines around here.
Cody
12-14-2006 19:12:14
 Re: BIG CARB in reply to Mopower, 12-14-2006 08:33:38
Alot of the bigger m's are running a belt drive govenors and using the big zenith carbs. Saves weight too.
Mopower
12-15-2006 03:10:06
 Re: BIG CARB in reply to Cody, 12-14-2006 19:12:14
Oh, like Olivers do. Wondered if they did that. Cool!
