building a gleaner e motor.
WCPULLER
12-13-2006 17:46:40
anyone know what i can do to a gleaner e motor to make it big and what parts??
mlpankey
12-17-2006 01:13:00
 Re: building a gleaner e motor. in reply to WCPULLER, 12-13-2006 17:46:40
hey curt how do you dyno youre motors . i cant seam to find a pto to handle 150 . when i get my 13:1 back together .im taking it to a buddies chasis dyno. just curious what torque did youre motors over 11:1 build since i think you said why on gods green earth would you want that much compression. youre stats look inpressive never pulled ntpa . never had worse than a fourth place finish in 2 years .pull from 3500 to 6000 . pulled two 5000 king of hills for money came in second . fuel pump decided to quit . crank broke at the last one.
CrazyAllis Kurt Hamel
12-17-2006 14:27:33
 Re: building a gleaner e motor. in reply to mlpankey, 12-17-2006 01:13:00
I direct drive the motor right off the flywheel.You will find that with the right ring seal at 11.25-1 it will build more HP and most importantly the torque is a lot higher.Unless you are turning in excess of 3500rpm the lower comp. engine will out pull the high.The highest comp. I use is 11.25-1, but they will leak down under 4%.Cranking comp. is higher than any 12.5+ engine I've ever tested.Remember it takes power to compress that charge,so get the head and manifold,carb and cam matched so you get a good cyl. fill and the mixture correct and they pull!Tune it on a dyno and PROVE the package.
12-15-2006 12:37:45
Give me a call, 308 493 5699.We build up to 150+ HP out of these in NATPA Div 3 and 4.Check results a NATPA.com from Ogallala pull.3 tractors and 6 first place finishes.
mlpankey
12-13-2006 20:22:39
yeahp e mail me .
