13.6 - 38 or 14.9 28????
H Puller
12-11-2006 10:10:30
Which do you think will be better for a 350 Utility? Run a 13.6-38, or Keep with the 14.9-28?? I will be running a TA. I've heard some say the 28inch will help with any lack of horsepower. But, others think the 38 will help gear up, and then I can use the TA to gear down. Just looking for some more opinions in order the help make my decision.
puller1
12-12-2006 17:40:57
 Re: 13.6 - 38 or 14.9 28???? in reply to H Puller, 12-11-2006 10:10:30
I run 13.6x38 & 18.4x34 cuts on my utility it speeds you up a lot,you better have a good motor to go with it
bm3501466
12-11-2006 14:52:05
I run 16.9 26s. They are taller than the 13 28s. I wouldn't go with a much taller tire. You definetly need to go a little taller so you don't have to put as many weights up front.
Shaggy
12-12-2006 15:06:37
 Re: 13.6 - 38 or 14.9 28???? in reply to bm3501466, 12-11-2006 14:52:05
Do you need another pair of 16.9sx26's? Shaggy
