Airplane fuel
Kane
04-20-2002 11:14:48
we pull with a '57 450 gas in the 6500 and 7500 lb classes in our area and we have been hearing that guys have been using airplane fuel either as an additive or 100% for gas tractors in antique classes. we were wondering if anyone out there has used airplane fuel or if it works, any replies are appreciated
deadeye
04-24-2002 04:41:12
 Re: airplane fuel in reply to Kane, 04-20-2002 11:14:48
U.S.A.F. has 115-145 octane if you have a way of getting it without going to jail. Lots of luck!!!!! !!!
JDGnut
04-23-2002 10:06:09
On the AV fuel.. (fuel from airports) check the octane rating.. as someone below posted.. most is 100 Low lead.. (very dry.) just add some Marvel Mystery Oil to it and U will good to go.. (Its states how much to add on the bottle.) A very few airports will have a higher octane fuel. (for the higher octane fuel.. look for a small airport that services Crop dusters. (some like the high octane fuel.) Good Luck
JDGnut
Kurt
04-22-2002 03:36:45
It does have an odd smell to it so if your pulling anywhere thats strict antique I'd becareful, it only takes one time to be thrown out and you'll always be considered a cheater. I like to use Cam2 it's smell doesn't give you away and really helped alot on not fouling plugs in my Dads "B". Have fun!
Dan Kelley
04-21-2002 19:48:21
One good thing about av-gas is that it already is stabilized for storage. Many folk top off their aircraft to keep condensation to a minimum, and then won't go flying for a couple months.
I agree with others. No sense using the purple 130/140 racing aviation fuel, if your compression won't use the octane.
Myth: The higher the octane, the greater the btu's of heat in the gasoline. That is dead wrong, and is just the reverse. There are less btu's of heat in higher octane gasoline. That's why it doesn't knock at higher compressions. That's the only reason for using it.
A low-performance DC-3 would actually lose power with 130/140 av-gas, because the blowers could not be set high enough to take advantage of the fuel, and the reduced btu's of heat could actually be felt in longer take-off rolls and reduced carrying capacities.
The 130/140 av-gas was created for WWII fighters, which had multistage superchargers, high initial compression and high spark advance. Anything less than 130/140 would knock and blow holes in cylinders. When using lower octane fuel, those aircraft have to keep the blower in low, and watch the boost levels.
Rule of thumb: Use the lowest octane gasoline that does not knock in your engine at full load. You'll get the most power for your combination, and get the best mileage.
Now, 87LL (Low Lead) av-gas is excellent fuel for many things. Pity the EPA won't let us use it in our cars. As I said, it's already stabilized for storage, and has better vapor characteristics for preventing vapor lock in the summer. Here in Colorado, it has better vapor characteristics for driving in the mountains. Good stuff.
G Taylor
04-21-2002 19:34:20
If your engine requires the octane, Av Gas is designed for low rpm long stroke hot running engines.100LL is good stuff & doesn't foul plugs as fast as old style high lead content fuels.A 50/50 mix with 94 octane pump gas with give almost as much octane due to lead's characteristic effect on unleaded fuel. Automotive race fuel has burn rates intended for 9000 rpm car engines.
buckmaster700
04-21-2002 05:33:40
i dont know why but av gas in time will burn out your valves try some VP sunoco or turbo blue racing gas it has the lead aditive in it and you wont have the valve trouble
ihcSuperM
04-21-2002 15:24:58
 Re: Re: airplane fuel in reply to buckmaster700, 04-21-2002 05:33:40
AV fuel will work fine. Yes it is very dry and I could see where it might cause a problem with valves. If you don't want to spend 4.00 a gallon for racing fuel, put some Quiksilver 2 cycle engine oil mixed in with the gas. a 1:64 ratio (1 ounce per gallon) is all you need. That will give you the lubrication for your valves and your tractor will not smoke.
Chuck
04-20-2002 21:23:18
I use airplane gas in my F-20. I don't see any increase in hp but it seems to run better and idle better. It is a higher quality product and it is very dry. I think the octane is around 102. It smells great. If you don't have high compression there is no need to buy racing fuel but av gas is better than regular gas.
Jim M
04-20-2002 20:05:24
I was wondering if airplane fuel is legal to use in NATPA pulls?
Andy
04-20-2002 19:21:35
I have used it,I think it helped my Super M.
Irv
04-20-2002 12:18:29
I have, did not gain anymore horse over premium
unleaded. My tractor's comp ratio is 8.2 to 1.
Irv
04-20-2002 12:18:28
Willie
04-21-2002 05:43:05
 Re: Re: airplane fuel in reply to Irv, 04-20-2002 12:18:28
That is all that I use. If I put regular gas in my tractor then it smokes a sputters when I throttle it up. I know that I probably have about 220-240 lbs. of compression but airplane fuel is 1.80 dollars a gallon compared to 4.00 dollars a gallon for anything else. I guess that I am just to tight to buy anything else. I think that it works very good.
