Difference between 300 and 350 Farmall Heads?
H puller
12-09-2006 08:14:47
Is there any difference between a 300 and 350 farmall head? Will the 3 5/8 stepped head piston kit for a 350 go in a 300 block without any machine work?
buickanddeere
12-09-2006 17:37:06
 Re: Difference between 300 and 350 Farmall Heads? in reply to H puller, 12-09-2006 08:14:47
50
H Puller
12-09-2006 12:01:35
If I was to buy a 350 Utility, where could I find a set of hubs to put 9bolt pressed steel on the back instead of using the factory 8bolt hubs?
ChadS
12-09-2006 11:47:03
No physical difference in the two heads,,, Ys, the 350 kit will go right in the 300 block. Chad
