Unstyled A
RJ
04-19-2002 19:07:13
I have a unstyled JD A with a late A crank and pistons. Bored .125, head ported. Problem is when tractor is running it runs ok, but, when you open the pepcocks, the RPM come up 2-3 hundered RPM then when you idle down it dies. Timing is set at 0 TDC.
burns
04-20-2002 17:46:56
 Re: unstyled A in reply to RJ, 04-19-2002 19:07:13
With the longer stroke of the late A crank, I'm sure you notice an increase in your compression. With the petcocks closed the tractor has to work a little harder to compress the air/gas--opening them will make it a little easier thus a change in rpm. My G does the same thing on an idle. I'm just under 10:1 with 205psi static compression.
