MW add powr pistons AP-10 What for?
farmall-tractors
12-07-2006 18:14:31
What will my 4 m&w add powr pistons fit with no. AP-10 ? STD size pistons, don"t know what that size is, it has STD and A on the top of each 4 pistons. They are NOS and I have a picture of them in the Help Identify gallery. Thanks.
Ken B.
12-08-2006 02:57:45
 Re: MW add powr pistons AP-10 What for? in reply to farmall-tractors, 12-07-2006 18:14:31
can you put a tape mesurement on them it real hard to tell anything now
farmall-tractors
12-08-2006 06:13:44
 Re: MW add powr pistons AP-10 What for? in reply to Ken B. , 12-08-2006 02:57:45
I measured it best I could and it measures 10 inches around. Do you have any idea what they fit??? Thanks.
jhb
12-08-2006 12:15:21
 Re: MW add powr pistons AP-10 What for? in reply to farmall-tractors, 12-08-2006 06:13:44
Does that measure as a 1.6 inch diameter? Sound very small. Normally we measure diameter of piston at top.
farmall-tractors
12-08-2006 18:00:39
 Re: MW add powr pistons AP-10 What for? in reply to jhb, 12-08-2006 12:15:21
jhb, they measure approx. 3 inches acroos top. Thanks.
ChadS
12-08-2006 13:22:10
Just measure across the top with a tape measure. They look to be a small pin piston, so if its 3-9/16 or 3-5/8 bore they were for a 300-350 tractor,,, if they are 4 inch, or 4-1/8th bore they are 400-450. Wont know till he measures across them. Chad
farmall-tractors
12-08-2006 17:59:31
 Re: MW add powr pistons AP-10 What for? in reply to ChadS, 12-08-2006 13:22:10
They measure approx. 3 inches across the top. Any ideas? Thanks.
ChadS
12-09-2006 12:30:07
 Re: MW add powr pistons AP-10 What for? in reply to farmall-tractors, 12-08-2006 17:59:31
maybe for the little farmalls,,, Cub, A,B maybe a C?? H's were 3-3/8 bore starting,, Chad
farmall-tractors
12-09-2006 19:00:09
 Re: MW add powr pistons AP-10 What for? in reply to ChadS, 12-09-2006 12:30:07
ChadS, Do you know what the bore is for those small Farmalls? Or what might these fit of those, or what"s the closest??
CPR
12-10-2006 04:38:27
 Re: MW add powr pistons AP-10 What for? in reply to farmall-tractors, 12-09-2006 19:00:09
Super C, 100, 200 had 3 1/8 in. pistons... not sure on A, B, C... hope this helps.
CPR
