8043 head
tkb
12-06-2006 20:46:11
I have an h head with casting #8043DC or the last
D is worn ? is there a DD and a DC if there is is there any difference between the two.
How much increase in compression.
Any info greatly appreciated.
tkb
12-08-2006 17:13:24
 Re: 8043 head in reply to tkb, 12-06-2006 20:46:11
Thanks guys
D Slater
12-07-2006 10:14:46
Off of the top my head I think DD combustion chamber is sloped off some on side away from spark plug and CC is not. Think DD was used on SH tractors. If you can find date code on head that may give idea if its CC or DD.
ChadS
12-07-2006 13:26:44
 Re: 8043 head in reply to D Slater, 12-07-2006 10:14:46
Yep, 8043 DD is an exact replica of the 300-350 gas head casting,,, but with the old 4 digit casting code, but,,, DD is the last prefixes. DC, etc etc are H gas heads. DC heads,,, They are a decent cyl head, and you can mill the heck out of em and get some good results. Dave,,, how's things going out in your area????? Got cold here real quick. If its still warm there,,,, Ill send you some colder air.... special delivery! Chad
tkb
12-07-2006 21:28:03
 Re: 8043 head in reply to ChadS, 12-07-2006 13:26:44
Are you talking about just milling down gasket surface or reconturing combustion chamber.
minus 2 here last nite
Need something to do until the big thaw
Thanks in advance
ChadS
12-08-2006 13:17:19
 Re: 8043 head in reply to tkb, 12-07-2006 21:28:03
Cold enough! Yeah the gasket surface, or called cyl head plate. Plate thickness,, after milling should be no thinner than .300. You can measure it at one of the water ports with a set of small calipers. You can recontour the chamber in the DC heads,,,,, if your using firecraters,,,, you gain CC's, so it can possibly lower your cyl pressure, unless you have a huge domed piston to fill in the gap. 350 heads are still resonably priced,,,, so Id put money in one of those and have a tad over what you would spend working over the stock H gasser heads. JMHO,, Chad
D Slater
12-07-2006 19:18:41
Cold made it here today.
