I can't imagine belonging to a club that could care less about such a safety issue. I enjoy pulling but would have to walk away from that club and find somewhere else to go. As mentioned below centrifugal force is exponential to RPM. Force "squares" everytime RPM goes up. Double the RPM, then 4 times the force. Triple the RPM and 9 times the force. Faster you turn it the force begins to really multiply. Take a piece of cast iron that is 50+ years old and ask it to survive that kind of force? Just crazy! A scatter blanket will not contain a 100 lb flywheel that has exploded! They are only meant to catch the pieces that get past a true scatter shield made of steel or THICK aluminum. I would never dream of turing a stock flywheel more than 20% over and that is probably pushing you luck. If it is cracked then stock RPM isn't even safe! I too pull a Farmall M with a V8. I can't imagine leaving the Farmall flywheel in there! The V8 has a steel flywheel with a Chevy clutch, crome molly input shaft machined to fit the Chevy, a new input coupling for the transmission machined, and a 60 pitch chain coupling. The whole mess is covered up with 3/16" steel to contain the parts if any of it fails and then the "tunnel" is wrapped with a blanket just in case. If it blew up and hurt me it would be bad. If it blew up and killed someone there to watch it would be the end of the world for me! Saftey is more for the crowd than the operators. We understand there is a risk. They are just there to watch and have a good time. First time one explodes that will be the end to getting insurance. Well, off my soap box. Hope you can convince the club of the importance of slowing those things down. Unless they have really spent some money inside the motors just twisting them up isn't doing anything HP wise but making more noise!
