What to mix with Diesel to boost cetain.
IK
04-18-2002 19:09:14
What can I mix to my diesel to boost the cetain. My tractor need the higher cetain.
IK
04-22-2002 06:05:25
 Re: What to mix with Diesel to boost cetain. in reply to IK, 04-18-2002 19:09:14
Thanks. My tractor need the cetain to start because in the summer even if its a 110 degrees outside it would still need either to start. I've used cetain booster in it and it feel as if it picked up some power. When I take of in 6th geer it will now take off at an idle, before I put the cetain booster in it would no even take off at full throtle, it would just stall.
Goldsburg
04-19-2002 11:02:36
Why do you believe that your tractor needs more cetane?
Do you know what cetane does for a diesel? It is not more power! Only better starting!
The cetane improvers for diesel fuel are actually of a lower density than the fuel itself. So while you are improving the starting and idling characteristics, the power output (BTU content) per unit volume of fuel injected will actually DECREASE. Unless you increase the amount of fuel delivered, you will see only a loss in power.
The best power fuel you can get your hands on is the thickest "straight" #2 diesel you can find....
Regards,
Goldsburg
dale
04-19-2002 12:05:57
 Re: Re: What to mix with Diesel to boost cetain. in reply to Goldsburg, 04-19-2002 11:02:36
What about these mineral spirits/diesel combos i am hearing about? Are they worth a try?
chad
04-18-2002 21:21:48
cetain booster avaiable at any auto parts stores or gas stations....
