wd45 puller engine
jd plowboy
11-28-2006 17:57:43
i am building a wd45 pulling engine. i am using the wd45 crank with the 4 1/8 bore. it has a set of dished pistons in it now. i also have a set of m&w ap48 pistons. which set of pistons will give me the most compression and horsepower.
mlpankey
11-30-2006 19:26:31
 Re: wd45 puller engine in reply to jd plowboy, 11-28-2006 17:57:43
look at a flat top small block 400 chevy if the compression height is taller thats where the pin goes then it will come up higher in the block really given you alot of compression. i run mine at .400 in the hole for 13.5 compression ratio.
CrazyAllis
12-04-2006 18:19:12
 Re: wd45 puller engine in reply to mlpankey, 11-30-2006 19:26:31
WHY ON GODS GREEN EARTH would you wnt 13.5-1 comp. in a 2000rpm tractor motor?I have built and spent enough hours on a dyno with AC motors to assure you 11.5 is the upper limit. from ther on up you will give up HUGE amounts of power and torque.Small cid near stock will do great at 9.5 and down.Don't go by cranking pressure, figure true comp ratio.
jd plowboy
12-05-2006 13:53:34
 Re: wd45 puller engine in reply to CrazyAllis, 12-04-2006 18:19:12
in the other reply which pistons do you think would work the best and give the most compression.
slowmo57
12-01-2006 09:17:36
I have a wc with a d17 will thoses piston bolt wright in? How much hp gain on average from soup bowl to chevy flat top? thanks John B
d17
11-29-2006 16:05:52
Don't most people just run a D-17 engine?
Kip[UT]
11-29-2006 06:13:18
The M&W's should have a heart shaped dish as opposed to the round dish on standard 45 pistons. Therefor the M&W's should give the highest compression. If this is a dedicated pulling tractor, you can use the WC/WD flat top type pistons & really raise the compression.
jd plowboy
11-29-2006 17:54:39
 Re: wd45 puller engine in reply to Kip[UT], 11-29-2006 06:13:18
i also have a set of the wd M&W AP46 pistons. which out of the three would give most compression. want to get to 200 psi if possible.
