hard blocking!!!!!!
Eldo case
11-28-2006 08:45:11
Will a .062 wet sleeve cylinder hold up with hardblock?? If not how thick should be the minimum be? Thanks!
mlpankey
11-30-2006 19:30:41
 Re: hard blocking!!!!!! in reply to Eldo case, 11-28-2006 08:45:11
some use the window sealant for car glass i like the loctite sleeve sealant myself.
B BARENIE
11-29-2006 17:59:05
 Re: hard blocking!!!!!!/DREW ! in reply to Eldo case, 11-28-2006 08:45:11
I HAVE 95THDS IN TWO SPOTS OFF THRUST SIDES,(FRONT TO BACK). ONE WOULD BE IN THE HARD BLOCK AREA, THE OTHER WOULD BE THE SECOND SEGMENT DOWN.
RUNNING IN THE BORE ON A SMALL STROKER MOTER!
WHAT WOULD ANYONE RECOMMEND FOR A SEALANT TO ADD ON TOP OF THE HARD BLOCK (MORROSO) TO FUTHER INHANCE SEALING
ALL INFO WOULD BE APPREACIATED
AC
11-29-2006 19:11:55
 Re: hard blocking!!!!!!/DREW ! in reply to B BARENIE, 11-29-2006 17:59:05
Always liked Moroso Cerami-seal or POR-15. I have some Caterpillar yellow 3M stuff I have used too. Works well.
Phil Munson NY
11-29-2006 10:08:14
Eldo:
I would carefully note what Drew says, he is very knowledgeable and competant. best Yeoman
Strange Brew
11-28-2006 15:32:49
If your not turboing it, you'll be fine with hardblock, if you run water some in the block, you may get a leak after a while, but that will depend how your shop sets in the sleeves, and also how hard, rpm's your turning it.
Eldo case
11-28-2006 14:50:48
Cast. They are a dry sleeve, but would work good in this tractor that is a wet sleeve without boring if it would hold dry blocked. Thanks!
Drew
11-28-2006 09:03:06
You need atleast .125", and more if you can get it. What material are these .062" sleeves you are looking at?
