G cam question.
DSK
11-27-2006 11:39:35
I'm building a 6.5x 9 G for a customer. He wants to use the stock F900R cam and a set of high ratio rockers from Murphy's. A 597 cube G is not that big and I guess I'm just wondering if this will be enough caming to feed it. The rockers are $300, and the F900 is a good stock grind, but I think he would be better off with a regrind from Berry or Iske and forget the rockers. Anyone out there running this combo? All opinions welcome.
ttp
11-27-2006 19:39:07
 Re: G cam question. in reply to DSK, 11-27-2006 11:39:35
could you clerify what you mean about that do you feelschooler is proud of his cams a little too much do you know of any better grinds?
Scott Boehler
11-27-2006 17:14:05
I run a stock F900r cam in my G with a set
of true roller rockers made by R & R Machining
out of Beneld Il. I have 4 extra sets of these for sale. Kit includes everything, Shaft,rockers,
adjuster bolts & lock nuts.Shop phone# is217-835-
4579. His name is Randy.
Tree Topper
11-27-2006 14:38:28
I am running a 623 cu. in. G with stock cam, it does have shortened rocker arms and is working real well. I have a set of rockers that have been shortened more than the ones I am running now. You might want to check with Allan Schooler about shortening you some rockers. I have not put the shorter ones on my tractor yet. Hope this helps.
3020
11-27-2006 18:07:59
 Re: G cam question. in reply to Tree Topper, 11-27-2006 14:38:28
I hear Allan Schooler has a little bit of a representation problem, so I would be careful about asking his opinion. I would ask the cam experts.
