piston wall clearance on g JD
rookie puller
11-25-2006 12:14:53
how much clearance should their be between the piston and cylinder wall on a JD g bored out .125 to 6 1/4"? thanks.
skip 33652
11-25-2006 15:40:46
 Re: piston wall clearance on g JD in reply to rookie puller, 11-25-2006 12:14:53
minimum .0015" per inch of bore size for steel pistons.002" per inch of bore for aluminum.Or .009" for steel Or .012" for aluminum this is minimum.Paul
rookie puller
11-25-2006 21:20:34
 Re: piston wall clearance on g JD in reply to skip 33652, 11-25-2006 15:40:46
thanks for the info. I didn't have a bore gauge but did manage to fit .023 worth of feeler gauge between the piston and cylinder wall. so i suspect i'm somewhere between .025-.030 clearance right now. explains my power loss.
