Deere Blocks
Mopar-Harris
11-23-2006 17:00:36
Will a 720/730 series gas block bolt up to a 70 gas?
Toot
11-28-2006 13:24:42
 Re: Deere Blocks in reply to Mopar-Harris, 11-23-2006 17:00:36
Its pretty well here in black and white before you. G block will not bolt up to 70 gas, only the 70 all fuel. 720-730 block has no spark plug holes, plugs were in the head, and used a totally different piston style and size than the 70's and G's.
bassndeere
11-24-2006 19:50:25
Hello,
Sorry, but it will not work. JD moved the spark plug location from the block to the head on the 720/730 series. Don't know if you use the 720/730 head it might. I am wondering if going the other way might work. How about a JD G block? At least that the direction I'm looking at now.
Good luck and have fun with her.
JDBert
11-27-2006 07:20:28
 Re: Deere Blocks in reply to bassndeere, 11-24-2006 19:50:25
A "G" block wont work on a 70 either- UNLESS its a all fuel 70.
bsndeee
11-28-2006 01:30:04
 Re: Deere Blocks in reply to JDBert, 11-27-2006 07:20:28
Mornin'
Will the JD G block bolt to case? Will the JD 70 head bolt to the JD G block? Might give larger cubic inch to start at 6 1/8" and bore up from there. And JD G pistons are easier to find. I'm just asking, can't find JD 70 LP pistons. Lots of afermarket G parts.
JDBert
11-29-2006 07:08:55
 Re: Deere Blocks in reply to bsndeee, 11-28-2006 01:30:04
Look for a set of M&W ap141's- thats a 6 1/8 piston for a 70 LP- there WAS a set on ebay- I'm thinking they are in MO but cant remember they did not sell. thats a 250 overbore on your 70lp and would give it a 8.5:1 compression ratio.
G and 70 gas blocks and heads ARE NOT compatible whats so ever.
Drew
11-28-2006 09:00:59
The 70G has 10 head studs, the G only has 9. I am 99.9% sure the G block will not bolt to the 70G crankcase.
block
11-28-2006 13:02:46
 Re: Deere Blocks in reply to Drew, 11-28-2006 09:00:59
wasn't there just 1 "Jerry's Block" for the 70/G? How'd that work?
