10 MPH - Radial or Bias Tires
Hooked
11-20-2006 11:48:53
If you are pulling in a 10 MPH class would you prefer radial tires or bias tires and why?
Thanks for any advice out there.
Eldo case
11-21-2006 05:52:57
 Re: 10 MPH - Radial or Bias Tires in reply to Hooked, 11-20-2006 11:48:53
Radial will hop bad at 10mph I know for sure!!!!! !!
Hi good friend Liberty La
11-20-2006 18:04:31
It doesn't really matter what tire you run. If the moisture is high for the day it will be different versus the next day. Bias good one day suck the next etc.
Dave in MN
11-20-2006 17:28:37
Make sure rules allow radials
Hooked
11-21-2006 05:51:43
 Re: 10 MPH - Radial or Bias Tires in reply to Dave in MN, 11-20-2006 17:28:37
The rules allow radials and also cut tires for this class. Someone told me radials would be better at the higher MPH level.
Ian Johnsen
11-22-2006 20:44:39
 Re: 10 MPH - Radial or Bias Tires in reply to Hooked, 11-21-2006 05:51:43
I pull 16-17 mph with road worn bias plies, no problem. I would be more concerned with the shape of the lugs and air pressure. A newer set of radials may be softer and wrinkle easier. Other than that, I don't see the benefit.
