White Pine Tn Pull
TN PULLER
11-20-2006 06:16:09
Thanks to all the nonmembers and out of state pullers who came and pulled. Dont know what the final number of hooks was but there was a lot.
more power
11-21-2006 06:53:42
 Re: White Pine Tn Pull in reply to TN PULLER, 11-20-2006 06:16:09
wow what a great pull, who was the kid on the cockshutt that won the 5500 open gear, was he from ohio, i could not believe he beat that hot moline
was at the full pull line
11-20-2006 18:02:15
all so the g that won was shorter than the 1st. g the 1st. g was 239 the case was over 250
11-20-2006 14:59:45
3 tractors made full pull in 8500 but 5 pulled
gfs
11-20-2006 17:10:09
 Re: White Pine Tn Pull in reply to was at the full pull line, 11-20-2006 14:59:45
I was there as well, must be blind even though I recently had 20/10 vision at the doc's office. Let's see, the case went out, the big G from Ky, the MM dsl, the G from Blountville to start the class, and the G from Blountville at the end. The big MF was on his way till he blew the horn, where is your complaint. I watched 5 go out and 5 pull off; out of this group who was in the pulloff that didn't full pull.
11-20-2006 17:48:15
 Re: White Pine Tn Pull in reply to gfs, 11-20-2006 17:10:09
the jd with black side was 1st.pull and 2feet short of full pull line
gfs
11-21-2006 10:42:47
 Re: White Pine Tn Pull in reply to was at the full pull line, 11-20-2006 17:48:15
Like I said I must be blind, there was a whole gang of us that saw Vernon go out pretty dang easy, matter of fact, I thought they would reset the sled. If that was the only thing wrong and I don't think it was then there is really nothing to complain about. BTW, the guy riding the sled said he made it out.
11-21-2006 11:15:08
 Re: White Pine Tn Pull in reply to gfs, 11-21-2006 10:42:47
rules say 1st.tractor make a full reset???? it is on a tape plane to see??
