Stroking an M
Flyin Farmall
04-17-2002 18:35:44
how much stroke can a guy go with stock rods?1/2"safe?haw about an inch??what rods should a guy go with if you need different?I need some suggestions here,starting to do the tractoor,and pullin season starts soon here!!!thanx.
Red 1
04-20-2002 00:27:45
 Re: stroking an M in reply to Flyin Farmall, 04-17-2002 18:35:44
6.5" stroke with stock rods and a 478 navistar (IH) truck piston (4.5") works well. 413 cid
Biggest problem you will have is keeping the sleeves from moving (down) in the block. I would try having them welded in place if I were to try it again. I think Head shop in Neveda Ia does it.
Flyin Farmall
04-18-2002 19:04:01
how much can I go with my firecraters??or should I start looking for pistons right away??never built a stroker,so lots of questions.thanx!!
randy hall
04-18-2002 21:17:12
 Re: Re: stroking an M in reply to Flyin Farmall, 04-18-2002 19:04:01
you can't stroke the crank any if you want to use your old pistons and rods.
Puller of Farmalls
04-19-2002 15:29:27
 Re: Re: Re: stroking an M in reply to randy hall, 04-18-2002 21:17:12
I am told m and w 179 piston is still available 4.25 for half inch crank stock rod.Minimal clearance grinding.Get you70 horse or more depending on which head other mods etc.THIS is a good dependable setup for afirst effort.I am currently putting together an incher and am dicovering lots of little pitfalls.Whatever you decide figure everything out and get prices, availability etc before you have the crank made.
Flyin Farmall
04-21-2002 11:02:27
 Re: Re: Re: Re: stroking an M in reply to Puller of Farmalls, 04-19-2002 15:29:27
what about the 4.25 pistons in a straight M not a super?I was told they wouldn't fit,or you had to run without sleeves,OR that you will hit water on anything over 4"????what is the deal here???thanx alot for the advice!
DRR
04-19-2002 18:15:18
There is no grinding necassary with 179 M W 1/2 inch stroke.Very reliable 326 cid.
randy hall
04-17-2002 20:48:56
using stock rods you can go up to 6.5". you should get ahold of keith merfeld at peosta iowa. he has a lot of experience. good luck !
Puller of Farmalls
04-22-2002 15:38:03
 Re: Re: stroking an M in reply to randy hall, 04-17-2002 20:48:56
Flying Farmall when i started out I would have appreciated some first hand comments I couldnt get.Rule no 1 big inches cost big bucks.The mand w 179 is the only piston I know that uses stockrods and stroker crank.ON my setup however for some reason one cam lobe ticked the rod.Do check carefully for clearance.4 inch is as big as you can go on m block without biring.4.625 or more is possible costs lots.MIDWEST cylinder haed in nevada Ia.will do.On the 6.25 I am building broke into oil gallery on no 2 crankpin and reqiring lots of rod griding to clear the cam.Consider using different rods on longer strokes.Lemmons tr. in Rushville In.good plsce also.I am not trying to argue with anybody just passing on my hard won experiances.
DRR
04-22-2002 18:42:26
 Re: Re: Re: stroking an M in reply to Puller of Farmalls, 04-22-2002 15:38:03
Built my 326 4 yrs ago w/281 block and stock 450 rods no grinding was necasary with cam at stock timing marks but very close.Have put many hours on this engine as it is still used to earn its keep.
