BUDD!!! I found it!!!
ChadS
11-15-2006 12:38:58
I found one of them there fancy testers and where to get em. they hook up in the spark plug hole, dont have to disconnect the push rods, its supposed to measure the volume of a cyl by how much air the cyl pumps into the guage puts it into a measurable reading,,, Im passing the info onto Terry,,,, so he will be in touch. ChadS
Maxpuller
11-21-2006 05:42:59
 Re: BUDD!!! I found it!!! in reply to ChadS, 11-15-2006 12:38:58
WWW.speedwaymotors.com
1155puller
11-17-2006 21:44:19
Yeah, but it seems like it is going to be a fuss either way with a diesel because its either pull an injector or drop the oil pan. Seems to me that a class that has rules on displacement (650c.i. for instance) should have a practical way of inspecting an engine, or it shouldnt be a rule.
mlpankey
11-15-2006 20:18:10
you can get one at local round n round track or drag strip .while youre there you may want to check into a digitron meter it will tell if anybodies adding juice to there fuel by the specific gravity of the fuel mixture .propylene oxide make one go nitro make one lug better than any stroker crank and then hydrazine well its band by the nhra for what it will do.
AC
11-17-2006 16:05:50
 Re: BUDD!!! I found it!!! in reply to mlpankey, 11-15-2006 20:18:10
Theyt arent hard to find. A regional Michigan touring group, SOD, (Sprints On Dirt) has a few. A person can probably get one through them.
I dont know if they would work for a diesel.
Besides, you know what kind of fuss its gonna make to go and disconnect a diesel line, bent it back, pull an injector..etc..
1155puller
11-15-2006 19:44:31
I would also be very interested in just such a device. Is there such a thing that can be used on diesel engines as well?
