Oliver front end
Too heavy Olive
11-13-2006 20:55:29
Can anyone tell me any disadvantages of a single wheel narrow front over a regular 2 wheel narrow front? Also how do they compare for weight to each other for pulling?
Cody Adgent
11-15-2006 20:49:55
 Re: Oliver front end in reply to Too heavy Oliver, 11-13-2006 20:55:29
The 77 front hubs will fit an 88, and an 88, 195GK, 310, 320, 1100 massey, 265, 283, 1650, 1800, 1850, and 1750 engines will ALL bolt into a 77 tub. As for the frontends, the 66's are about 25lbs lighter than a 77 frontend. A 22 massey frontend is alot lighter than a 66 but takes a little work to get it under there.
770 Puller
11-14-2006 23:08:35
how many pounds do the 66 front bolsters shed? I heard this know it all down home talking bout em mounting up one time, figured he was full of it, guess not
new kid in town
11-15-2006 05:05:49
 Re: Oliver front end in reply to 770 Puller, 11-14-2006 23:08:35
the 66 narrow front with pressed steel wheels is the lightest factory front & will bolt right in. can get lighter by building hubs and using 12" rims.
Doug Boll
11-14-2006 05:00:55
do you have pressed steel rims, if not I have a set with hubs
green in mich
11-16-2006 08:26:24
 Re: Oliver front end in reply to Doug Boll, 11-14-2006 05:00:55
looking for pressed wheels & hubs for tricycle 77. let me know what you have & how much
Too heavy Oliver
11-14-2006 07:10:50
I have a wide front and want to lighting up and I'm looking for the best set-up.
Cody
11-14-2006 12:47:30
 Re: Oliver front end in reply to Too heavy Oliver, 11-14-2006 07:10:50
A 66 frontend will be the lightest direct bolt up frontend. You can get lighter if you want to get creative.
will a
11-14-2006 12:55:26
 Re: Oliver front end in reply to Cody, 11-14-2006 12:47:30
77 front tub fit a 88?
new kid in town
11-15-2006 05:00:35
 Re: Oliver front end in reply to will a, 11-14-2006 12:55:26
the88 engine won"t fit the 77 tub.
U sure?
11-15-2006 10:28:34
 Re: Oliver front end in reply to new kid in town, 11-15-2006 05:00:35
There is 2 oliver 77's in our club,, that both have 88 engines in em. Looked like the block bolted right in the tub,,, but had to alter the driveshaft length to sit in the frame.
new kid in town
11-17-2006 20:47:03
 Re: Oliver front end in reply to U sure?, 11-15-2006 10:28:34
your right it will bolt in. my mistake.
