Oliver block
super 88
04-16-2002 19:51:21
do any of you guys outhere know how gingerich installs the sleeves in these big bore oliver blocks. dose he stop it at the bottom or dose he hang it from the top .how thick do these sleeves need to be thanks for any help
TimC
04-17-2002 13:46:54
 Re: oliver block in reply to super 88, 04-16-2002 19:51:21
How big do you plan on going. 590 and up gets touchy but can be done and made reliable, (that is a relative statement). Hard block would probably have to be used once you get past a certian point and you wouldn't want to pull back to back. Re routing the oil is not a big deal.
Extra clearance for the pistons\sleave is a big deal. Do it. IMHO the sleaves are hung from the 1 inch plate on top and the bottom of the block is sealed up with hard block. If you are going smaller then you could probably be more flexible.
I like the idea of grinding the sides of the cam rather than turning it down on a lathe. I'm not an engine builder but have given it a lot of thought and listened to a lot of speculation.
once heard
04-17-2002 15:46:56
 Re: Re: oliver block in reply to TimC, 04-17-2002 13:46:54
I once heard that the sleeves in the big gingerich motors stepped down in size three times towards the bottom of the block. that left more meat to help prevent the block from splitting down the middle. also heard that they left the sleeves sticking up .003" above the deck to get good head gasket seal.
Who's Worries About Gingerich 88's Anymore???
04-19-2002 09:02:03
 Re: Re: Re: oliver block in reply to once heard, 04-17-2002 15:46:56
The answer.....NOONE!!!!!.....except the tach man!
TimC
04-17-2002 18:11:27
If it is secured it beats having to have the head or block ringed.
aren't u just the expert!
04-17-2002 20:06:11
 Re: Re: Re: Re: oliver block in reply to TimC, 04-17-2002 18:11:27
what have u ever built that won anything of importance!!!
Seamo
04-20-2002 08:03:27
 Re: Re: Re: Re: Re: oliver block in reply to aren't u just the expert!, 04-17-2002 20:06:11
Yes we have won alot of pull's. Lets be more helpful to each other. Earl Seamands
OK EARL!!!
04-20-2002 10:21:52
 Re: Re: Re: Re: Re: Re: oliver block in reply to Seamo, 04-20-2002 08:03:27
Thanks for slapping all our wrists!!
TimC
04-18-2002 18:43:28
And your point would be?
Call Brady Morrow
04-17-2002 07:43:11
Call Brady- He'll tell you how Gingerich does it...which he'll VERIFY is NOT the way to do it! Better yet, I bet he'd sell you his motor!!
