what to do with a H
daniel gillespi
11-08-2006 20:10:34
I am mind boggled with all the stuff you can do witha H. I want to build something just past the stock range but not a money buster. I have 3 3/8 pistons. Should I bore the block and is so what to put back in what type of sleve etc. Or just pull the sleves and install 3 7/16 eninge kit like in the engine kits on this forum. I want to use the crank do i need to regrind it? Where can i get dome pistons to get more compression? I"ll take any other advice or suggestions! I have read through the post but am trying to explain what my situation is
MJF
11-10-2006 11:46:35
 Re: what to do with a H in reply to daniel gillespie, 11-08-2006 20:10:34
The best thing to do is listen to chad he knows what he's talking about, and he won't steer ya in the wrong direction
daniel gillespie
11-08-2006 20:21:06
i was thinking of putting the farmall 350 piston kit in what all would I needd to do swap this in
ChadS
11-09-2006 10:05:01
 Re: what to do with a H in reply to daniel gillespie, 11-08-2006 20:21:06
Your looking at boring the H block, to the 350 sleeve barrel size, have the 350 sleeve flange cut to the H sleeve spec, and the 350 sleeves work in the H block. makes 175ci, firecraters are prety much to option for most rebuild kits, and yes, there is a little bit more you can do to get more out of the engine by playing with the wrist pin location on the rod, and fitting the piston in the head more to make more compression, low end torque, then add some newer parts like a cam, intake can carb if allowed, maybe a cyl head if its an older gas head, or worse, a kerosine head. Chad
daniel gillespie
11-09-2006 16:34:11
 Re: what to do with a H in reply to ChadS, 11-09-2006 10:05:01
Will the connecting rods work on the 350 work on the H crankshaft. What 350 part number that is listed on the engine kits on the forum would you recomend
ChadS
11-10-2006 12:40:32
 Re: what to do with a H in reply to daniel gillespie, 11-09-2006 16:34:11
Yes, use H rod bearings. The piston kits are prety much a firecrater piston set, so not much option other than that, unless you get lucky and find a high dome set, probably wont find new,,, Chad
