310 waukesha
M Bray
11-08-2006 17:48:33
How big of a bore and stroke can you get in this block and still have a dependable motor?
HULKSTER
11-11-2006 19:22:45
 Re: 310 waukesha in reply to M Bray, 11-08-2006 17:48:33
Just build a 310 diesel.and still have the cubes
neverwin
11-09-2006 19:28:59
easy 310 build Buy a set jd 4020 m&w sleeves and pistons. Offset grind crank 2.00 inch and use 77 rods. Cut the top off of pistons and you will have a 425-433 cube engine that will go together very easy.
L.D.W.
11-10-2006 15:51:32
 Re: 310 waukesha in reply to neverwin, 11-09-2006 19:28:59
Would work pretty well, but, doing it that way theres few things I don't like, with the thicker sleeves, got to take more out of block than needed, the pistons are heavy doing it this way, it's ok if you're running in pretty limited classes, but I prefer the light forged auto style pistons. we have used the 77 rods too, next time I wont though, when you offset grind with those rods, the rod ratio is not at all favorable, next one we do will be aluminum rods, longer of course.
Drew
11-11-2006 11:14:36
 Re: 310 waukesha in reply to L.D.W., 11-10-2006 15:51:32
You do not want aluminum rods. You will not gain any horsepower, and they have a finate lifespan. Dont get too caught up in the rod/stroke ratio. I have seen stuff with a pretty low rod/stroke ratio turn lots of RPM for several years and has yet to have a problem.
confuzed
11-10-2006 19:46:46
Why would you want aluminum rods? That little bit of weight you would save would eat up 1/4"-1/2" of room that you could make up with more stroke. Stroke it till you run out of room.
L.D.W.
11-12-2006 16:43:00
 Re: 310 waukesha in reply to confuzed, 11-10-2006 19:46:46
It's not really a weight savings standpoint in the motor for the style we run, when you crank a lot of rpms, with the stoked crank, the longer center to center makes for a better rod ratio, which DOES help. yes, I've seen the short rod motors run a long time too, but, if you want to maximize what you have, then you do it the right way, and get the numbers you should have in the motor. Another plus is if you use the chrysler rods, forged with the small journal, 2" or 1 7/8" , which clear fine, you can pick up a long center to center, up to 7.850.
Cody Adgent
11-08-2006 17:56:42
You can go 4.375 and still be ok. Have seen one that was 4.5 bore but it was a nightmare to seal.
L.D.W.
11-08-2006 21:37:36
 Re: 310 waukesha in reply to Cody Adgent, 11-08-2006 17:56:42
we have one at 450 ci, could definitely go bigger, but will be reliable, and we are going over stock rpms as well.
ANON
11-09-2006 17:13:44
 Re: 310 waukesha in reply to L.D.W., 11-08-2006 21:37:36
I'm curious--what bore and stroke? What sleeves, pistons, rods?
M Bray
11-09-2006 02:54:49
How big of a stroke can you go in the 310 block? Can you get more than a S88 or 880 block? Thanks
L.D.W.
11-10-2006 15:46:04
 Re: 310 waukesha in reply to M Bray, 11-09-2006 02:54:49
If you guys want, shoot me an email, give you some info that might help.
