NATPA Engine Rule Question
Crusty Beater
11-03-2006 04:13:11
I have a question about this rule in Div 3 and 4:
13. No increased height in any tractors (ie: deck plates, shims, girdles) except for stock gasket.
My tractor is not stroked and only bored .060 over, but my factory replacement block is slightly taller than the original. It bolts on with no modification, deck plate, shim, or girdle and uses only a stock gasket. Is this ok?
Captainhookerus
11-03-2006 15:14:20
 Re: NATPA Engine Rule Question in reply to Crusty Beater, 11-03-2006 04:13:11
This is one place NATPA rules save you from yourself. The 340 engine came out in the GTC tractor on LPG, a good U on LPG made it look like a fool. 4 1/4 bore 10B2800 cylinder blocks are 2 inches taller than the 10A149. This engine also had a 6 inch stroke. This was never a replacement engine for any U farm tractor.
What you want is a later crankcase that has a flange mount starter instead of those miserable set screw mounted inertial engaged SOB's.
Is this is your intent or are you reading serial number books and playing what if games?
Ken
Crusty Beater
11-04-2006 14:25:11
 Re: NATPA Engine Rule Question in reply to Captainhookerus, 11-03-2006 15:14:20
We are running the 340B-4 crankcase. I replaced the 4.25 10B2800 tall blocks with 4.625. Yes, that's right regarding the GTC. This was also used in a U Military tractor standard from the factory, but not "replacement" so to speak. Several U Industrials escaped with 340B-4, but only the UMIL and GTC were documented as factory stock with this engine.
David
11-04-2006 18:13:34
 Re: NATPA Engine Rule Question in reply to Crusty Beater, 11-04-2006 14:25:11
So in other words, you want to pull with a G or GB engine in a UB and call it stock? I would like to do that too, but most organizations won't allow it. You said it was just .060 over, but a 4.625 is more than .060 over the 4.25 bore a UB has stock. Also the 6" stroke you have isn't stock, it is a full 1" over a stock UB. So you have more than a little over stock UB. A little taller block, two inches taller isn't a little taller. I'm sorry to burst your bubble, but you are not fooling anybody with your so called "stock" tractor.
Crusty Beater
11-05-2006 07:27:17
 Re: NATPA Engine Rule Question in reply to David, 11-04-2006 18:13:34
Nope, never claimed it was a "stock" tractor nor trying to fool anyone. According to rules as written, I have a legal Div3 tractor. I'm simply trying to prevent hauling to an event and told to pull Div5 based on others' experiences. The rule specified "i.e. no deck plates, shims, or girdles" My engine is 4.685 x 6 and 100 h.p. The block height is identical to factory U-series' Military. Mild next to a normal looking 283 engine running 727 cubes haha.
David
11-04-2006 09:49:32
 Re: NATPA Engine Rule Question in reply to Crusty Beater, 11-05-2006 07:27:17
You need to check the rules again.
The 340 block height (which you don't have, you have the G, GB blocks) are 2" taller than the STOCK UB blocks making them NOT legal. The 340 was NEVER a factory replacement engine for a U or UB.
Unless you are planning on stroking the engine with a huge stroke, you would be better off finding a set of SHORT 4.625" blocks and using your crank with an offset grind and aftermarket pistons for div. 3.
Crusty Beater
11-06-2006 06:51:17
 Re: NATPA Engine Rule Question in reply to David, 11-04-2006 09:49:32
That is probably what I will end up building in my 1946 UTU with a Welters 4.81 piston. Good engine from what I've seen in DIV3.
But yet, am I really increasing the deck height if the UMIL, a variety of the U-series tractor, was FACTORY EQUIPPED with the tall blocks?
SERIAL # PREFIX:
056 340B-4 Gasoline Engine for UMIL Tractor
057 UMIL Tractor w/340B-4 Engine
SERIAL #:
1953 340B-4 05600001 - 05600042 1953 UMIL 05700001 - 05700042
What about a Deere power block? Exception to the rule?
David
11-06-2006 07:57:43
 Re: NATPA Engine Rule Question in reply to Crusty Beater, 11-06-2006 06:51:17
I totally agree with you on the John Deere aftermarket blocks. The rules should be equal for all makes, no exceptions.
Your explaination of the UMIL still won't hold water. That was a limit production, non agricultural tractor that has no association with a UB. Just because it is in the U series, it had more in common with the G tractors. Again, the 340 was never a factory option or replacement engine in a UB. Till the rules are changed to stop holding the MM's back from using factory parts when certain makes can run performance purpose built, non factory replacement parts, that is how it will be on the tall blocks on an U derivative. Sorry.
Crusty Beater
11-06-2006 08:31:47
 Re: NATPA Engine Rule Question in reply to David, 11-06-2006 07:57:43
Thanks for the clarification Dave. Wasn't trying to be argumentative, just trying to see NATPA justification. It's a good organization. Henederson Power makes a 5.75 bore from a stock U block and it still runs water through it. To this day, I still don't believe anyone can match the cubes of MM. The dealers had fun with that! As far as Deere. It seems they get a favorable shake. It's hard for a Deere to compete. They require some extra effort and money, then I see a few do really well.
call RICH
11-03-2006 05:17:04
Call Richard Wenzig, head of the tech for the NATPA, see if you get an answer without him having to check with someone else before answering!
Gary Baker
11-03-2006 05:14:11
If it's a direct factory replacement block it will be the same deck height. You are not giving me enough information. What model tractor are you talking about? Gary
?wonderingg?
11-04-2006 12:19:35
 Re: NATPA Engine Rule Question in reply to Gary Baker, 11-03-2006 05:14:11
Gary,
The Jerry's block is legal for the G JD in Div 3.
it is longer than stock! How long is allowed?
Does it depend on who it is or where it came from?
Use a tape and measure one, they are longer than an unstyled block, can the same be done with other models?
just wondering where to draw the line, thankyou very much
Crusty Beater
11-03-2006 06:04:21
Hello Gary. I am talking about my old M-M UBU with a 340B-4 engine from a UMIL. The block height was different from most model U. The crankcase is identical.
answer
11-03-2006 13:08:47
 Re: NATPA Engine Rule Question in reply to Crusty Beater, 11-03-2006 06:04:21
div 1-2 NOT LEGAL Div3,4,5 LEGAL--come pull and have fun
Crusty Beater
11-04-2006 14:26:59
 Re: NATPA Engine Rule Question in reply to answer, 11-03-2006 13:08:47
Thanks, I will!
Barnheater
11-03-2006 19:01:36
What's the rules on a 403 in a "U"?
