Cylinder head work
Jim in little T
11-01-2006 15:44:52
I have a few questions you guys who do cyl head work. I have a guy who can do my head. Im just not sure what he is going to do is worth it. He is going to drop my stem size .100 thou and increase then int head dia .060 and the ex .025. Does this really help that much? He also said he would grid them on a .030 angle. Thanks for the advice.
jd mechanic
11-03-2006 11:08:24
 Re: Cylinder head work in reply to Jim in little TX, 11-01-2006 15:44:52
That will incease your flow quite a bit.Whether or not it helps you depends on cubic inches, rpm, and carb size also how effeciant it is stock.WITH A TEN Percent rpm increase and or slight overbore it will pick up a bit of power.Too small a valve stem you will drop a valve.
