massey 44 power
kwf
10-30-2006 04:44:21
What is best and most economical way to get 80 to 100 horsepower out of Massey Harris 44.
paul knecht
11-06-2006 06:02:27
 Re: massey 44 power in reply to kwf, 10-30-2006 04:44:21
If you can find an old set of 4 1/16 M&W pop up pistons, that's a start. You can shave 0.150 off the head, put in a set of 55 valves. Bore out the intake above the carburetor as far as possible, then find a carb off a 530 Case backhoe. I had one like this @ 80 hp with racing fuel.
kwf
11-06-2006 06:37:57
 Re: massey 44 power in reply to paul knecht, 11-06-2006 06:02:27
thanks, this is the stuff I am looking for. Where can I find these pistons and sleeves and 55 valves. Also how much would a safe stroke be on the crank, and were would be a reliable place to get this done.
thanks
buickanddeere
11-01-2006 15:31:35
If I recall the Continental could be built into 65HP with just a overbore sleeve/high compression kit. Valve bowl blending, port matching and a mild cam. You need to look at the other end of the tractor and take care of traction 1st. All the extra HP does is throw the dirt farther when she spins out.
keddano
10-31-2006 17:52:17
My understanding is that the Chrysler 6cyl 85hp engine could be had as a std. engine.Also a Chrysler 110HP flathead will fit right in.I had twin ones in a old wood boat I had. I know a marine junkyard that should have a few around.
docjoe
10-30-2006 16:18:38
Trade it for a u moline! Those old yellow dogs are the cheapest hp for your dollar spent by far.
