Timing ajustement
jdjack
10-29-2006 13:43:46
I have the JD A hooked to the dyno, and started to play with timing. I am turning mag. clockwise and horsepower jus starts to increase. And I can"t turn the mag anymore. How can I turn it more? I beleive that clockwise is advancing it--right?
Has a mag on it and has short lugs.
JDMark
10-29-2006 16:16:36
 Re: Timing ajustement in reply to jdjack, 10-29-2006 13:43:46
jdjack, Turning your mag clockwise is retarding the timing. If you want to you can pull the lefthand cover (flywheel side)off your governor and retard the governor gear one tooth and see if that helps you on the dyno. Good Luck JDMark
