How much more can I strip my 70
John179
10-27-2006 12:22:33
I am looking to lighten up my 70 as much as possible. With cast wheels and a ridgid narrow front I am at 6300 with me on it. I am taking off the cast wheels and putting tine wheels on it. I am looking to try to get into 5500. I have removed oil bath, and cut down the fuel tank. and plan on putting in a alum radiator. Is there any other sugestions. Is there any way to make it a bare bake with no pto or hyd?
Mike Aylward
10-28-2006 05:57:07
 Re: How much more can I strip my 70 in reply to John179, 10-27-2006 12:22:33
John, my 70 by itself weight right around 5300 lbs. I fabricated a front end, have a lightweight rear cover, all hydraulics removed, weld-on axle plates installed, light steel rear rims, smaller front rims, pto removed, air cleaner removed and a fabricated one installed, fuel tank replaced by a 6 lb. plastic one, lightweight brackets, and the radiator replaced by one out of a compact tractor. I would still like to find another 100 lbs. to take off of it and have another possibility there. Hope this helps. Mike
ChadS
10-28-2006 10:49:04
 Re: How much more can I strip my 70 in reply to Mike Aylward, 10-28-2006 05:57:07
How much does the main hood weigh? I know of a person who can make em from aluminum, or really close to stock looking,, Chad
SwIa JD 70
10-27-2006 18:49:47
Press Steel, 15.5tires, Low fuel ,5 gal trans oil,No PTO, Wheely Bars, 100 lbs front wts. driver I weigh in at 6000 lbs. Move draw bar to 18 inchs and front will rise at end of pull. If flat back and no Hyd pump I think you should make it.
Mike n Mo
10-27-2006 13:13:15
Make a rear cover out of sheet metal, use about 16 guage or so. make a seat post out of light material, use a pan seat. Put the battery out front either on or under the front weight bracket. Use only about 3 gal of lube in the trans/rearend. This might get you in the ballpark. Mike
John179
10-27-2006 13:16:06
 Re: How much more can I strip my 70 in reply to Mike n Mo, 10-27-2006 13:13:15
Do you think I will be able to balance the tractor very well in 5500?
Mike n Mo
10-28-2006 11:11:32
 Re: How much more can I strip my 70 in reply to John179, 10-27-2006 13:16:06
You won't have much if any moveable weight. On a good track it'll probably be light on the nose. Mike
