Rim Widening?
Jack
04-14-2002 08:20:42
I was wanting to know if maybe some machine shops would take on the task of adding about three inches of width to a 2 inch drop center rim.I can get some 12.38's but need to widen to 15 wide.14's are common but our rules state that we can run 16.9's on a 15 rim.Thanks
Kurt
04-15-2002 03:42:55
 Re: Rim Widening? in reply to Jack, 04-14-2002 08:20:42
A buddy of mine checked out a shop that said they could widen his 24" rims but they wanted 150.00 a piece to do it!
Gman
04-14-2002 16:30:06
Jack-- Miller tire sells new 14' wide rims.You can buy them new about as cheap as you can cut the rim and roll a piece to weld back in. Welding them back up isn't to bad but cleaning them up to make them look halve way decent is a noisy chore.The noise inside of rim sure does ring,ear plugs are a must.Miller Tire I don't have the Ph. no, but they advertise in GM an the Hook you might try Millertire.com this might work. Gman
buckmaster700
04-15-2002 07:01:36
 Re: Re: Rim Widening? in reply to Gman, 04-14-2002 16:30:06
if you are using a pressed 38 in wheel i went to a imp salvage yard got a pair of old 38 in clamp on duel rims had McBride welding in linton indiana plasma cut off the outside bead to the width i needed it takes less time and money you make 2 welds insted of 4 with a spacer ring i got lucky the salvage rim for ten bucks for the pair look for the ones rotted around the valve stim side the other side is probably still good for this
Mike Aylward
04-14-2002 12:21:08
Jack, where are you located? I can do rim widening on my tire cutting machine if the rim is a nine-bolt and have made several sets for myself and other folks. I am in northeast Missouri. Mike
Jack
04-15-2002 05:47:15
 Re: Re: Rim Widening? in reply to Mike Aylward, 04-14-2002 12:21:08
I was wanting to widen just the 12 inch wide rings that fit on the cast center.What would you charge to send me some 15 inch wide?I am still using my cast centers.
