Tenn pull
owens
10-23-2006 16:57:24
I went to a pull last Nov. in Marysville Tenn. It was inside. Can any one tell me what this years date might be? thanks.
Fergfarms
10-27-2006 19:58:23
 Re: Tenn pull in reply to owens, 10-23-2006 16:57:24
Pulled there the past two years.Had a great time.
Will someone please give us the correct dates and stop the gripping we hear enough of that during the year.If you don,t like things there stay at home.Its a great place to get together and meet pullers from other areas.
WEL
10-25-2006 07:02:10
I have been to the indoor pull at White Pine (Walters State) for the last 3 years. It is a very good pull and run very well. I encourage all to attend and pull there if possible. The only negative might be that it gets a little smoky in there after a while.
owens
10-25-2006 09:35:18
 Re: Tenn pull in reply to WEL, 10-25-2006 07:02:10
When is it? All these posts but still no date.
mlpankey
10-24-2006 20:03:26
i guess the eight year old girl that had to pull in outlaw because of cut tires . on her 880 and they also tried to change the 5000 lbs class to a heavier class before her dad protested because it wasnt on the paper isnt right . cut tires are allowed everywhere in antique 4 mile hour class except whitepine then youre an outlaw tractor whither you can run the speed or not.
OLIVER KID
10-26-2006 20:00:13
 Re: Tenn pull in reply to mlpankey, 10-24-2006 20:03:26
I THINK YOU ARE TOTALY CONFUSED MR PANKEY OR IS IT MR PINKY, WELL WHAT EVER IT IS I HAVE NEVER SEEN THIS BEHAVIOR AT THIS PULL BEFORE. SO IF YOU ARE DONE CRYING ON THE INTERNET COME ON AND HAVE SOME FUN, SIMPLE RULES, 4MPH NO CUTS , 12 MPH CAN HAVE CUTS
TN PULLER
10-25-2006 07:00:38
Dont remember a 8 year old girl pulling a 880. Plus dont remember her dad protesting,theres never been a change in weight classes. Get your facts straight.
mlpankey
10-23-2006 22:27:58
could you be thinking of hairman tn .they didnt have a pull this year just a show
mlpankey
10-23-2006 22:32:20
 Re: Tenn pull in reply to mlpankey, 10-23-2006 22:27:58
i personally wouldnt waste my time going to white pine . they dont like cut tires and there bad to change weight classes on you especially if thre worried that youre a contender
gfs
10-24-2006 06:15:41
 Re: Tenn pull in reply to mlpankey, 10-23-2006 22:32:20
you have got to be loopy, there are classes for cut tires and classes for uncut. As for weight classes they are listed on the sheet when you sign up. Been around this club since its inception and have never seen this treatment, I have seen rpm's checked, hitches measured and anything else to make sure folks play fair, but never seen wt classes get changed. 4mph uncut tires 12 mph with cut tires, been that way all year. My understanding is there is also going to be a tunica koh type classes this year.
owens
10-24-2006 10:38:26
 Re: Tenn pull in reply to gfs, 10-24-2006 06:15:41
well when is it?
gfs
10-25-2006 10:23:47
 Re: Tenn pull in reply to owens , 10-24-2006 10:38:26
November 18 starts early, check the Hook in coming events for contact info.
farmallguy3
10-23-2006 19:48:30
you must be thinking about the pull at walter state in the white pine morristown area, there is not an indoor track in maryville, tn. the pull at walter state is the saturday before thanksgiving i beleive
owens
10-24-2006 03:46:52
 Re: Tenn pull in reply to farmallguy3, 10-23-2006 19:48:30
Yes white pine rings a bell. Is there a date or a contact person? thanks
