Surging H Motor for Chad or anyone
H-Man
10-22-2006 18:45:51
Three good reasons for a surging H motor at full throttle no load stock motor. Thanks
ChadS
10-23-2006 11:01:26
 Re: Surging H Motor for Chad or anyone in reply to H-Man, 10-22-2006 18:45:51
1 too stiff of spring
2 vertical shaft is out of adjustment
3 weights in the governor.
weights can be shot, need new pins,, too tight of spring tension will cause the weights to shut down, open up shut down open up, (surge) need lighter weights inthe governor,,,, if the vertical linkage is out of adjustment, that can do it too. Chad
Goldsburg
10-23-2006 16:57:34
 Re: Surging H Motor for Chad or anyone in reply to ChadS, 10-23-2006 11:01:26
Poor transition fueling from idle circuit to main jet circuit is also a lesser known cause of no load surging. This could also be thought of as fuel control during "part throttle".
If you have modified your carburetor or if it is old and need of a rebuild, then I would seriously consider the poor transition fueling as the cause of your surge...
Regards,
Goldsburg
