Heisler head
virgils
10-22-2006 16:09:28
will a heisler head work on an unstyled A with high compression aluminum pistons.
bigmotors
10-22-2006 19:58:21
 Re: Heisler head in reply to virgils, 10-22-2006 16:09:28
The unstyle A heisler head has a cone that fits in the chamber. It looks like a bra! The tip of the cone - If I can remember I think is around 15/16 long. You can run high dome pistons .125 over with a late model crank 6 3/4. 52 to 55 horse tractor. YES you have to run racing gas. Nice set up.
Good Luck!
JD Bobby
10-22-2006 19:02:30
Which heisler do you want to use? Heisler is not GENERIC for Deeres or any machine they were designed for. As for av-gas go ahead valve guides are on there way, tell the U.P.S. man
2 Cylinder
10-24-2006 20:57:34
 Re: Heisler head in reply to JD Bobby, 10-22-2006 19:02:30
Haven"t needed valve guides yet, and I"ve been runnin this setup for over 10 years. A little Marvel Mystery Oil in each can of av-gas keeps the U.P.S. guy away.
2 Cylinder
10-22-2006 18:47:12
To my knowledge it should, you will probably have to use high octane gas such as aviation fuel, or Torco racing gas. To my knowledge the heisler head is a flat head. I have the flat head on my JD-G with high compression aluminum pistons and it work well, but I have to use aviation fuel or it will not run right, it spark knocks on regular unleaded gas. Hope this is the information your looking for.
JPatton
10-23-2006 18:10:12
 Re: Heisler head in reply to 2 Cylinder, 10-22-2006 18:47:12
2 Cylinder - You may have a flat head on your G but it is probably a John Deere head. If you have a styled G (1941 was the last unstyled model) that was very common to get a little more HP out of the old girl. Or if you are a puller it could be one from Jerry's out of Wichita Ks. I don't believe Heisler ever made a head for the G.
Wrong
10-22-2006 19:04:34
Wrong
