Gov Springs (again)
Shaggy
10-18-2006 21:30:12
Would you be better off running a stock spring instead of a real stiff one in the Division's that only allow you to turn 10 or 20% over stock? Thanks Shaggy
mark_ih4ever
10-21-2006 10:02:07
 Re: Gov Springs (again) in reply to Shaggy, 10-18-2006 21:30:12
Heavier spring is the way to go.
It will give you a bit more gound speed and be more responsive down low too....it is going to react quicker when the load hits you!
Not sure why the other message says a stock spring will work better down lower. You want you butterfly to open sooner!
Go with a heavier spring.
If you are funning an m, h or 300-450 get an old bed spring there about 15-20 % beefier.
LIGHTER SPRING
10-20-2006 05:58:52
The lighter the spring, more governor action
at lower rpm's. The heavier the spring more rpm's with governor action at higher rpm's.
jpl
10-19-2006 19:30:06
the stiffer spring is to overcome your gov weights, you can lighten the gov weights and run stock spring, i run a 560 and went to ih dealer and got new spring about 10.00, i can now adjust my rpm to 10% or 20% over, no problem. springs get weak over time and cant overcome the gov weights and drops your rpms. for a couple bucks you can get a spring at tractor supply thats a little longer and that should work.
Curious
10-19-2006 18:15:47
I was kind of wondering too. How about you Mr. Thinker or any others.
