Mike, The whole idea behind the rules at Washingtonville is to keep things simple - most of the time the only thing on a tractor that can be disputed is whether or not a tire is cut at our pull. We were the first pull in the area to seperate out cut and uncut tires, and it has been by far the best way to even the playing field in the pace classes - most of the other clubs in the area are following suite because they see that it works. For the most part (excluding BN), the uncut tire class has been the place where the average farm tractor or show tractor can come out and have some fun and be competitive without doing anything other than putting weight brackets on and getting the hitch up to 18". Our M that we pull in the uncut classes only has a 4" bore and 52 HP was within 1-3 points of winning the 5500-6500 classes for the year, and we never leave 1st gear. Being that the 5500 and the 6500 are nonpace, it's obvious that the big HP tractors are staying where they belong in the cut-tire classes. I think this past year has been better than the past few with guys getting into the right classes based on tire cut. Other than the BN in the light classes, I really haven't seen many other tractors consistantly running in the "uncut" division that belong in the "cut" division. The "cut" division was made for tractors like our strong M and H, Stine's C, Megargels, and others that are making some HP. Even at that, stine's M won a few classes for the year and it is only a super M engine in it compared the the HP that most of the rest of the class is making. Just goes to show that HP isn't everything. I like to go and pull and relax. We quit going to some pulls (Nisbet in particular) with our Stock 4" bore M in the past partially because of fuel prices, but more because we got tired of being harrassed over and over about the RPM's and if we had a 450 block. It was obviously not a 450 block, every time we went we were tached and found to be okay, and we ran in the same 1st gear that every other M was running in. We did well there because we had a set of tires that loved the track and we read the track pretty good. After 2-3 years of the same thing every pull, we got tired of going and feeling like we had a target on our back because we did well. The rules at Washingtonville do not allow for any of that nitpicking crap - just pick your tires out, hit the scale, and pull. Sorry to ramble - just trying to figure out what you felt sucked about the pull?? We'll take a look at them this winter and probably make very minor adjustments, but I don't think you'll see anything real drastic as far a changes.
