Oliver 77 pulling motor
Jeffrey Sharp
10-17-2006 11:05:32
I have a 77 Oliver and an extra Super 77 crank that I would like to offset grind to get a 4 inch stroke. Is there a stock 4 inch car/truck piston that will work with the Oliver rods? Has anyone done this modification before? Email if you have an answer.
stroker 88
10-17-2006 16:44:27
 Re: Oliver 77 pulling motor in reply to Jeffrey Sharp, 10-17-2006 11:05:32
the 77 sleeve won't take 4" bore.
Jeffrey Sharp
10-18-2006 13:38:40
 Re: Oliver 77 pulling motor in reply to stroker 88, 10-17-2006 16:44:27
I know that the block would require boring for a larger sleeve.
stroker 88
10-19-2006 04:21:01
 Re: Oliver 77 pulling motor in reply to Jeffrey Sharp, 10-18-2006 13:38:40
i haven't built any at 4" stroke. have used .060 over 366 gm truck pistons for some longer stroke engines for 4" bore.
