belly pump weight?
heavy M
10-16-2006 10:42:25
How much dues the belly pump and associated parts weigh?Also who makes the aluminum trans covers?How much do they save?Cost?Wanting to lose 400 lbs.Already know elt pulley 85 460 front end and wheels another 75 leaves around 225.Thanks.ps its a Farmall M.
cousin_gary
10-16-2006 17:19:36
 Re: belly pump weight? in reply to heavy M, 10-16-2006 10:42:25
What weight are you trying to make? You should easily make approx 4800 lbs with a narrow front, stock wheels, no belly pump and no pulley.
With removing a belly pump (not sure how much fluid is in it) I estimate the loss at less than 100 pounds. Is there a live pump on it and lines, maybe add another 30 pounds.
If you are really desperate you can drain some rear end grease. It won't hurt it a bit to run a bit low or empty for 1 or 2 runs. Don't drive it to the pull empty of fluid. Or you could look for a lighter driver.
Just my experience.
