IH Pump Info
Mark Redman
10-15-2006 10:20:14
Will a Roosa Master Pump fit on a DT 466 engine and if so, what is involved in making it work? Any help on this subject would be greatly appreciated.
jerry1
10-16-2006 06:09:40
 Re: IH Pump Info in reply to Mark Redman, 10-15-2006 10:20:14
Yes and no lots more to it than you think and I am like the other guy why ? But it can be done. If you loke a a ih 361/407 it has a pump dirve hub mounted on the front timing cover you use this part and adapt to the 466 opening trick is you are on the other side of the engine Have to consider things like pump rotation and then you will need to work out the lines. The 466 gear will have to re bored to fit the 407 drive shaft
Sheepdog in NE
10-15-2006 18:24:36
Why????? ?????
Mark Redman
10-16-2006 05:46:56
 Re: IH Pump Info in reply to Sheepdog in NE, 10-15-2006 18:24:36
Well, in some of the areas that I pull in they only allow roosa master pumps on them. Thats why I was wondering? Any ideas?
