weld in straps to widen rims
joecool
10-14-2006 08:13:54
Does anyone have any info on where to buy some straps to widen rims? need 2 to 3 inch straps for 38 inch rims.
Mike n Mo
10-14-2006 11:56:37
 Re: weld in straps to widen rims in reply to joecool, 10-14-2006 08:13:54
Just buy a 20' long of 1/8X2 or 3" strap iron at your local steel supply house. Some shops can even roll it for you, or roll it yourself but clamping one end to somethong about 30" in diameter and wrapping it around it.I use a 7" cut-off blade in a circular saw to cut the wheels, took 3-4 blades for each. Mike
colekicker
10-14-2006 10:33:01
Just buy a 16"x38 double bevel rim. Cut it in half, cut your other rims edge off and then add the half of the double bevel to your other rims. That way you only have one weld on each rim compared to two.
