Jd cams
Mark Martin
04-11-2002 16:38:37
where is a good place to get good pulling cam for a JD B
Gman
04-12-2002 19:25:54
 Re: jd cams in reply to Mark Martin, 04-11-2002 16:38:37
Mark there are alot of good Cam people out there,in my '51 "G" I have a 720 Isky cam.Cornett Machine shop in Somerset Ky is a good source,you might want to furnish your own specs,or tell David what you got and he will make a suggestion.You want be disatified with a Cornett cam,he grinds for a lot of California speed shops.Roberts is a good person to do business with I have one of his "G" carbs and it's a good one.Gman
G-MAN
04-11-2002 16:54:33
I am by no means on expert on this subject, but I think most places will have you send in your cam to be reground. There are so many different variables involved in different engines, that it would be impossible to produce different grinds to meet them all. I have seen "stock" and "puller" grinds advertised, but I don't know what that entails. I plan on sending mine to Robert's, and they are supposed to grind it to match my engine specs. Just my two cents.
Mike F
04-11-2002 19:14:24
 Re: Re: jd cams in reply to G-MAN, 04-11-2002 16:54:33
When the time comes, I'll be going to roberts too. Have heard all good there.
